Author: Subject: r 1carb emissions! sva setup
kev R1
posted on 8/8/06 at 05:11 PM Reply With Quote
anyone know of anyone who's done this for sva (apart from mac 1)
or anyone know who can set it up!!
hhhhhhhhheeeeeeeeeeelllllllllpppppppppp
smart51
posted on 8/8/06 at 05:31 PM Reply With Quote
My local Hi-Q let me use their MOT emissions machine for free. Guess where I'll go to get my next set of tyres.
I had the standard carbs, jets and needles with a foam filter instead of an airbox and with a cat before a standard R1 exhaust can. Once I'd fitted a better cat, all I had to do was adjust the idle screw on each carb to get lambda in the range, then I tweaked it to lower the HC. CO emissions were really low.
It might be worth checking that your carbs are balanced before you go.
amalyos
posted on 8/8/06 at 08:48 PM Reply With Quote
Did you use the MNR Cat with the std R1 Can?
zxrlocost
posted on 8/8/06 at 10:18 PM Reply With Quote
Ox advised me but I put my own exhaust system together.
after renting other companies stuff that didnt work and cost so much going backwards and forwards etc I should have just bought one in the first place.....
right then
standard air box
air filter OUT!
MY twin CAT system
Mixture screws set to a quarter of a turn out(this is a guide line they can be different)
I got 113 HC 1.03 Lamda(ffewwwww)
And 0.00 CO reading
ta
chris
smart51
posted on 9/8/06 at 08:50 AM Reply With Quote
I used a cat that MNR got from someone else.
