lsdweb
| posted on 10/8/06 at 08:07 PM |
R1 Clutch Movement
Hi All
I've just finished fitting the clutch (hydraulic) mechanism to my R1 and wanted to know how much angular movement there is after all the slack
has been taken up.
Pictures here and
here
Many thanks
Wyn
Coose
| posted on 10/8/06 at 08:37 PM |
On a standard R1 there should be 12-13mm of linear cable movement. That should point you in the right direction!
Spin 'er off Well...
lsdweb
| posted on 10/8/06 at 09:33 PM |
Thanks.
As I don't have the standard clutch arm, it's not possible to 'convert' this into an angular figure!
Wyn
Coose
| posted on 11/8/06 at 04:17 PM |
Hmmmm.... I thought as much from your pics! If you measure the length of the arm centre to centre I'll try to compare it with mine over the
weekend to give you the linear movement for your arm. I don't really have the means of giving you an angular measurement.
lsdweb
| posted on 12/8/06 at 10:01 AM |
Thanks Coose
Could you measure your arm for me - from the centres of the two pivot points.
I can then work out what 12mm movement should equate to on mine
Regards
Wyn
Coose
| posted on 14/8/06 at 07:50 PM |
Sorry old chap, I didn't really get the chance to measure it before now. Anyhoo, it's 35mm between centres.
Hope that helps!
lsdweb
| posted on 14/8/06 at 10:08 PM |
Many thanks!
I can work out the angle from that so I can setup the mechanism to avoid kiling the clutch!
Regards
Wyn
lsdweb
| posted on 14/8/06 at 10:13 PM |
20 degrees!
Thanks Coose
Coose
| posted on 16/8/06 at 07:41 AM |
Nay botha!
