Author: Subject: POWER COMMANDER
matt.c
posted on 17/8/06 at 09:47 PM Reply With Quote
POWER COMMANDER
Sorry but it might be a silly question but what is a power commander?
What age engines need one?
which engines need one?
Cant you use the stock bike stuff?
How much is one?
how is it used and how to set it up?
Is there a website to show me what they look like?
Very confused
Thanks for any help with these questions.
cheers
matt
the moa 2
posted on 17/8/06 at 11:04 PM Reply With Quote
It is like a piggy back ecu which is used to change the air fuel ratio after changing say an exhaust or air filter on your bike. So it is useful when fitting a exhaust to suit your kit and with out i think it probably wouldnt run right at all.
If you type in power commander on ebay you will get a load come up and you should also on google.
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 18/8/06 at 08:04 AM Reply With Quote
Power Commanders are used only on fuel injected engines for fuel optimisation throughout the rev range. No good for carb bike engines which would need rejetted.
[Edited on 18/8/06 by scotlad]
spunky
posted on 18/8/06 at 08:47 AM Reply With Quote
As above, the later type power commanders can also change ignition timing.
They are a PITA to use unless you have the software loaded onto a laptop. Then you can tweak dynamically, using the buttons on the unit is very coarse adjustment.
Had one fitted to my car, but byassed it to pass SVA emmissions test.
The reckless man may not live as long......
But the cautious man does not live at all.....
