xico_ze54
| posted on 24/8/06 at 09:59 AM |
cbr 1000 - clutch, etc
Hi all,
1. bought a 1994 CBR 1000 engine, but I can't see how solve the problem of clutch.
I think there's no room for either propshaft path and clutch cylinder.
How do people who utilized this engine solve this problem?
and what kind of master cylinder must be used at the pedalbox?
2. in reutilizing CBR's instruments panel, how can we connect the speedometer, once in the origin it was connected to the center of sprocket?
3. this engine is in analysation. what kind of major points can I check to see if everything is allright?
any advices concerning other issues of this engine, I apreciate to learn about.
thks in advance.
Amadeu
xico_ze54
| posted on 24/8/06 at 10:02 AM |
quote: Originally posted by xico_ze54
Hi all,
thks in advance.
Amadeu
Shandylegs
| posted on 24/8/06 at 10:36 AM |
Look in the photo archive under the user name 'Kissy' for one option (Note: I never did drop him a thankyou note for taking the time to
photo this when I was struggling for ideas!).
If you are careful there is actually just space to keeop the cylinder in it's original location. Cut the cover so there is room for the prop
(You will obviously loose the speedo drive but I did not mind as I will be using an electronic device) You will probably have to remove the cylinder
mounting lug nearest the prop, but a bracket can be fabricated to pick up on the bolt directly behind the bleed nipple. If I get chance I'll
take a couple of photos of my solution.
Duncan
xico_ze54
| posted on 26/8/06 at 03:38 PM |
Duncan
"Kissy" folder has nothing within it it's empty.
G.Man
| posted on 26/8/06 at 04:12 PM |
look in the for sale folder
engine bay pics
Opinions are like backsides..
