Author: Subject: Non-Synthetic oil vs Synthetic?
amalyos
posted on 29/8/06 at 12:28 PM Reply With Quote
I currently have Non synthetic in my R1 (not used on road yet, about to SVA), but was wondering what the difference is to fully synthetic, other that the price .
I've been told that it may give clutch slip.
Any comments?
Steve.
Coose
posted on 29/8/06 at 12:35 PM Reply With Quote
As you can get 4l bottles of synthetic at just over the £30 mark, as opposed to semi for around £20 there's no question really! Especially bearing in mind that the motor usually gets thrashed to within an inch of its life (once carefully warmed up).
I use Motul 300v or Rock Oil Synthesis 4 - both top quality and protective oils as each other.
[Edited on 29/8/06 by Coose]
Spin 'er off Well...
posted on 29/8/06 at 12:47 PM Reply With Quote
Not familiar with bike engine/g/box set-ups, but why would would using a different oil result in clutch slip - surely if oil is getting on the clutch then you have an oil leak somewhere?
Coose
posted on 29/8/06 at 12:52 PM Reply With Quote
Most bikes have wet clutches....
amalyos
If I change to fully synth, do I need to drain the oil and change the filter, or should the system be flushed?
Coose
posted on 29/8/06 at 12:55 PM Reply With Quote
Just drain the oil, change the filter and refill. No need to flush as they will mix quite happily.
Oil falls in to a similar category as tyres - it just isn't worth skimping on either!
posted on 29/8/06 at 01:36 PM Reply With Quote
something learnt
Phil.J
posted on 29/8/06 at 02:27 PM Reply With Quote
Just make sure that you get a bike specific synthetic oil. Most 'car' engine synthetics contain additives to reduce friction even further, and this can make a bike wet clutch slip under load.
Phil
Coose
posted on 29/8/06 at 02:37 PM Reply With Quote
Phil
Yep, very true. I forgot to mention that.
StevieB
posted on 29/8/06 at 05:02 PM Reply With Quote
The R1 service manual states SAE20W40SE or SAE10W30SE if it helps.
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 29/8/06 at 06:30 PM Reply With Quote
i reckon if the bike engine manufacturers say one type, be it mineraL or synthetic, then thats what to use. After all it was designed with that specific oil type in mind!
G.Man
posted on 29/8/06 at 07:23 PM Reply With Quote
You would think so wouldnt you, but most manuals actually give options... They give an oil viscosity rating and usually recomomend a good quality semi or full synthetic..
Only oils with friction modifiers need be avoided for a wet clutch
Opinions are like backsides..
Coose
posted on 30/8/06 at 07:49 AM Reply With Quote
The weight of the oil (i.e. 10W/40, 15W50) just allows for the optimum ambient temperature range. There is a lot of crossovers in these ranges, so it's not really that critical. The important point is the oil classification (SF, SG, SH, SJ etc....) - this describes the testing processes that the oil has been through to allow a 'quality' grading. Go for a good synthetic and it will be well up the grading list....
StevieB
posted on 30/8/06 at 08:03 AM Reply With Quote
What about oil levels? Obviously, bike engines are designed to be mounted in a certain way and under centrifugal force when cornering keeps the oil in the sump.
Then we come along and stick the engine in a car at a different angle than it's designed for, that corners flat, so the oil moves around but the engine stays on the same plane.
Does this:
a) Make sense
b) Cause a problem
c) Is it just not worth worrying about?
Coose
posted on 30/8/06 at 08:06 AM Reply With Quote
Have a look here.
No disrespect, but BEC sumps, dry/wet sumping and baffling has been done to death. Use this to find out more!
Coose
posted on 30/8/06 at 08:08 AM Reply With Quote
Ooooh, StevieB - is that of Steve Smart Roadster fame? If so, helloooo and tell Mark he's fat!
StevieB
posted on 30/8/06 at 08:11 AM Reply With Quote
I'll shut up then!
StevieB
posted on 30/8/06 at 08:15 AM Reply With Quote
Wondered how long it'd take to catch on!
Roadster now gone - got Diesel Volvo (I insisted that the next car is a mans car - even if old mans car!)
Mark's out of the office, so I'll tell him he's fat if he rings up to hassle me about soemthing (usually about 9:30)
Coose
posted on 30/8/06 at 08:20 AM Reply With Quote
Get some work done you skiver!
It was only once I read your location that it clicked who it was! I'm not the sharpest tool in the shed sometimes (and still slightly hung-over from Sunday night to be honest!)....
The sump baffle plate on eSkip is what you want (so long as your motor is pre-'03). The man who makes them is a star and does a lovely job. Then, go to York Yamaha Centre and get a sump gasket and the job's almost done! After fitting the baffle plate, overfill with oil until the level is at the top of the sight glass when warm and ticking over. It's tried and tested on R1's and seems to work!
p.s. Sorry for the thread hijack!
