Author: Subject: brake update
mad-butcher
posted on 30/8/06 at 06:21 PM Reply With Quote
brake update
need some general advice. I want to update the front brakes on the blade to willwood for trackday use. the budget is tight which willwood calipers do most of you guys use and apart from pads is there anything else i need or are they a direct replacement i'm running ventilated disks
many thanks
tony
scoey m
Builder
Posts 209
Registered 8/2/06
Member Is Offline
Photo Archive Go!
Building: MNR Vortx r1(sva pass 07 plate yumyum)
posted on 30/8/06 at 06:30 PM Reply With Quote
Hi
I purchased full kit wilwood powerlite caliper disks + pads for sierra upright cost about 380 ish look sweet though
Gav
posted on 30/8/06 at 07:30 PM Reply With Quote
GTS do the fill kit inc pad and disks for and its the same from rally design £280 iirc The plumbing is a different thread to the seirra calipers so youll need new hoses too.
