Author: Subject: BEC wiring
matt.c
posted on 30/8/06 at 08:26 PM Reply With Quote
BEC wiring
Been thinking about wiring up a BEC.
Whats best to do?
1. Extend bike loom and just use that.
2. Use car loom with bike loom inserted.
How has everyone done theres?
matt
Jon Ison
posted on 30/8/06 at 08:32 PM Reply With Quote
I run bike engine loom alongside one for lights etc.......
when striped out the engine loom is quite small including charge circuit etc, if you extend the bec loom there a few things you need too add,
hazards
rear fog
That's the way I do it anyway.
posted on 30/8/06 at 08:41 PM Reply With Quote
Quite messy extending the bike circuit, and as jon says, there are extra circuits needed. If you really wanted to do this, i suppose you would find a few fuses free in the bike fuse box. However, IMHO its much tidier to fit a proper car loom with a universal fuseboxes etc and proper switches, rather than using all the bike bits.
mkblade
posted on 30/8/06 at 11:35 PM Reply With Quote
hwen i wired up my 919 blade i used premier loom and kept the bike loom stripped out and bits of bike loom i did not want and webt from there
si
Coose
posted on 31/8/06 at 07:13 AM Reply With Quote
I extended the bike loom and added extra circuits. That way you get lovely little flasher and headlight relays etc, which are a lot more compact than you're average car unit. I only extended where I really had to though so I could keep as many of the bike connectors intact as possible. I works a treat!
Spin 'er off Well...
adrian
posted on 31/8/06 at 07:39 AM Reply With Quote
Premier loom is exellent Quality and easy to install, also it uses standard relays which are easy to get hold of
