Author: Subject: engine cuts out
tim windmill
posted on 15/10/06 at 07:15 PM Reply With Quote
engine cuts out
installing a 2004 fazer into an mk indy, coupled up the fuel pump using the bike loom and the sierra ignition switch.with the fuel hose disconnected at the carbs and the ignition turned to position 2 it pumps fuel through but after about 5 secs the pump stops. tried coupling fuel hose to the carbs and the engine fires up and runs but again after about 5 secs it stops.could there be a sensor that is kicking in and shutting down the pump. i am not using the bike clocks so do not have a fault code. any help appreciated.
the wiring as far as i am aware is the same as the carbed r1.
Jon Ison
posted on 15/10/06 at 07:28 PM Reply With Quote
If your that close too a runner feed the pump from live feed from ignition ? Put a switch in the feed if you wish ?
posted on 15/10/06 at 07:30 PM Reply With Quote
you could try rigging up a gravity fed system for the fueling, a few feet should be enough pressure to make ti run.
With my carbd bike engine the fuel pump is wired direct to an ignition feed, avoiding the bike loom. Obviously it regulates its own pressure etc.
MkIndy7
posted on 15/10/06 at 07:44 PM Reply With Quote
Put a bulb in place of the fuel pump on the loom, see if the bulb goes out after the 5 secs
If it does it the feed that dies.. if not it something within the pump itself.
Maybe its just a priming phase it goes through before startup and then it gets its running feed from elsewhere?.
tim windmill
posted on 15/10/06 at 08:03 PM Reply With Quote
cheers guys i will do that its a lot less complicated than relying on the ecu to manage it.
jacko
posted on 15/10/06 at 08:54 PM Reply With Quote
Fit a PINTO back in [ where is mr Hellfire ]
Graham
NeilP
posted on 15/10/06 at 09:05 PM Reply With Quote
A lot of fuel injection systems do this and I was just about to start ripping out the entire wiring (cursing like a viking in the process) when a mate explained. The initial short run when you turn to live ignition (before you start) is to prime the fuel rail. The ECU then re-starts the pump when it picks up the missing tooth on the crank position sensor. If your not using that sensor then then ECU thinks that you've not started the car yet and hence it cuts out after 5 secs. As suggestions above - Wire it permanently to the ignition circuit...
[Edited on 15/10/2006 by NeilP]
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
DIY Si
I think that 5 sec bit is the initail priming phase to ensure the floats are full. As said, if this is the only thing stopping it, just hard wire it in.
Sun Tzu, The Art of War
tks
posted on 16/10/06 at 05:40 AM Reply With Quote
wouldn´t wire it hard in
in case of an accident pressure could be lost in the carbs and the fuel pump could be started!
just search for the other feed line from the mcu to the pump to enable it while engine runs / cranks..
Tks
posted on 16/10/06 at 08:31 AM Reply With Quote
Graham
G R I N
You know he won't
