shortie
| posted on 28/10/06 at 08:40 PM |
Gear linkage
Anyone know the best place to get the rods and rod ends used for the gear linkages on a BEC, I want to fit the paddle shift kit over the winter so
will need to make up a new mechanism.
Rich.
pathfinder
| posted on 28/10/06 at 09:08 PM |
I would get the rod ends from e-bay or your local bearings supplier (M6 are big enough in my opinion).
B&Q do a good selection of aluminium rod or steel tube, not the cheapest but you can buy it by the meter!
stevec
| posted on 28/10/06 at 09:11 PM |
For the rods I used 8mm bar and thredded it, The rod ends I got from Demon freaks,8mm Karting rod ends, Good enough and cheaper than some of the rose
joints.
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=MEDFP-M06
Steve.
[Edited on 28/10/06 by stevec]
ruskino80
| posted on 28/10/06 at 09:19 PM |
why not try cable? much simpler less joints=less play works for me,cables from mnr
tegwin
| posted on 28/10/06 at 09:20 PM |
You might like to try rs components for ball joints...
HEREis just an
idea of what they have...
nitram38
| posted on 28/10/06 at 09:34 PM |
Try Speedy cables. They will make push-pull cables with whatever ends you need.
chris_harris_
| posted on 29/10/06 at 08:04 AM |
Screwfix do stainless threaded rod by the metre. I got my ball joint type rod ends from richijenkin (or it may have been his brother ox) on this site.
Try a u2u for them.
Regards Chris
