mark.s
| posted on 30/10/06 at 09:53 PM |
spring rates
a quick question for the bec boys what springs rates do you use on the front
cheers mark
ChrisGamlin
| posted on 30/10/06 at 10:29 PM |
Hi Mark
I run 225lbs on the front, but there's not a lot you can glean from asking us lot unless someone has exactly the same suspension gemoetry /
damper mounting position as your car, because one car could have 500lb springs and another with 200lb springs, yet both have the same effective
springrate, which is the bit thats important.
You're probably better off asking in the Avon section as they should at least have the same suspension as you. Even if they aren't running
a bike engine, you can probably scale down the springrate by working out the axle weight difference between their car and yours, which will probably
get you closer than taking an average of all other BECs of unknown suspension geometry.
[Edited on 30/10/06 by ChrisGamlin]
Coose
| posted on 31/10/06 at 08:56 AM |
Exactly! A friend on mine runs 100lb springs on the front of his S2 Lotus 7 'Blade, most Strikers will be around the 130-150 mark, Locosts can
range from nothing to god-knows-what, so it's a difficult thing to quantify unless someone has the same set-up!
Sorry we can't be any more help....
Spin 'er off Well...
mark.s
| posted on 31/10/06 at 08:48 PM |
thanks for that chris, and coose just read what your building...you would get on with my mate just fine
cheers mark
