andyd
posted on 31/5/03 at 08:40 PM |
Stuart Taylor exhaust on a Luego 'blade
Anyone care to comment on whether you think a Stuart Taylor exhaust system for a Fireblade would fit a Luego chassis.
The reason I query it is that I believe that the ST cross member goes the opposite way to the Luego one at the point which the exhaust exits the side
panel. I don't want to take the chance and cough over £300 and find it doesn't fit although I'm sure one of you guys would buy it
off me for the same money so I'm not out of pocket.
Anyone?
MK9R
| posted on 3/6/03 at 06:59 AM |
No help at all for this question, but just thought i tell you that the Tiger racing ZX9R exhaust doesn't fit the MK very well. We are going to
have to do a bit of extra bending and cutting. The engine in the tiger must sit at slightly different angle and be a little higher in the chassis. The
exhausts front pipe is just touching the bracing tube, the collector is not horizontal and is sitting slight;y below the the chassis. It doesn't
need much modifying but needs it to get it perefct.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
westindy
| posted on 4/6/03 at 09:12 PM |
ST Exhaust - ZX9R
I used a ST system on my Indy, its works fine but you need to mount the engine in conjuction with fitting the exhaust system so that the front pipe
misses the diagonal - a good buy at £300 + drat
