Author: Subject: engine still cutting out
tim windmill
posted on 5/11/06 at 09:58 PM Reply With Quote
2004 carb fazer,i can get the engine to start but it runs for about 5 secs and stops. tried wirng the fuel pump so it is wired to ignition live and same result. i have shorted out clutch switch and side stand switch but it will not keep running.
for the short time that it does run it sounds sweet so i am sure its an electrical problem. have i overlooked something simple? any help appreciated
MkIndy7
posted on 5/11/06 at 10:02 PM Reply With Quote
Some flamable aerosol in the inlet(s helpers needed lol) after the 5 secs would rule out a fuel problem
Just incase it was beating the fuel pump or float chambers, 1 of those things you can't really see.
stevec
posted on 5/11/06 at 10:10 PM Reply With Quote
An old trick is to put a strobe timing light on it and observe if it is still flashing as it it dies, this can confirm spark is happening or not.
Steve.
rayward
posted on 5/11/06 at 10:13 PM Reply With Quote
is there a " tip over " switch in the wiring?.
if so have you overriden it(held right way up and pumped full of silicon sealer usually does the trick).
Ray
johnemms
posted on 5/11/06 at 10:59 PM Reply With Quote
close the gap on the plugs... if it helps u got a dodgy coil ignition pack
zzr1100rick2
posted on 6/11/06 at 06:59 AM Reply With Quote
have you got an immobiliser fitted to it if so sounds like it isnt seeing an engine running signal ?
chockymonster
posted on 6/11/06 at 10:31 AM Reply With Quote
Ray
I'd have a look for the Tip over switch if there is one. 5 seconds is what I've heard mentioned before for the cut out time
tim windmill
posted on 6/11/06 at 04:16 PM Reply With Quote
well done guys it was the tip over sensor,all sorted thankyou
rayward
posted on 6/11/06 at 04:18 PM Reply With Quote
jacko
posted on 6/11/06 at 06:29 PM Reply With Quote
What a PLONKER good to see it,s ok now
Graham
posted on 6/11/06 at 07:52 PM Reply With Quote
Graham
It's good to see you're keeping notes Graham for when you get round to converting yours......
Phil
jacko
posted on 6/11/06 at 08:24 PM Reply With Quote
Graham
Phil
Hi Phil how are you all keeping ? yes one day when i get fed up with all the power i have and want to down grade Graham
