Author: Subject: Fuel Hose ID
Gav
posted on 12/11/06 at 02:53 PM Reply With Quote
Fuel Hose ID
My blade pump has 10mm id hose but the local motor factors only has 8mm and is unwilling to order a roll of 10mm since no one buys it...
will 8mm do i should i order some 10mm from t'internet?
craig1410
posted on 12/11/06 at 05:36 PM Reply With Quote
The fuel pump for my Rover V8 has 10mm inlet and outlet so I had a similar problem. I ended up getting 10mm hose from someone like Vehicle Wiring Products to run from the tank to the pump and then I used a 10mm to 8mm reducer and ran 8mm copper microbore down the tunnel from the pump to the engine finishing off with some braided 8mm hose for the last couple of feet.
Craig.
rj
posted on 16/11/06 at 12:21 PM Reply With Quote
Hi , not sure if you want copper pipe , but if you do try your local builders merchant, both 8mm & 10mm pipe is used for gas or something
I have just plumbed in my ZX9R fuel pump and that is 10mm
zxrlocost
posted on 16/11/06 at 12:27 PM Reply With Quote
my fuel line in copper was 8mm on my r1
Gav
posted on 16/11/06 at 12:43 PM Reply With Quote
After some searching on t'interweb looks like 8mm will be fine
