Author: Subject: 2003 R1 Clocks km/h to Mph?
hobbsy
posted on 5/12/06 at 10:35 PM Reply With Quote
I've currently got 2003 R1 clocks in my Fury (2003 5PW injected) and they are in km/h however its running a yellow box so it approx shows the speed in mph although the units on the clocks show km/h.
Only problem is that its on max adjustment (-28%) and its not enough so its still over-reading by about 10-12 percent.
I know on the earlier clocks you can hold down Select for 2 secs to switch between km/h and mph but this doesn't work on these.
Is there another way of getting these into mph? I know there is a company called Scorpio electronics that can change them to mph for £60 but I might as well buy an mph set of clocks then sell my km/h ones as that would cost less than £60.
Either that or I could get a speedo healer which can do a lot more adjustment but that costs £60 and I'd still have clocks that read in km/h.
Any ideas appreciated.
G.Man
posted on 6/12/06 at 05:40 AM Reply With Quote
speedo healer and a sticky background for the clocks?
Opinions are like backsides..
hobbsy
posted on 6/12/06 at 09:21 AM Reply With Quote
That is one option at £60. But I've already got a yellow box so if I can buy some mph clocks for ~£100 say and sell my km/h ones for £70 then its only cost me £30 for example.
Just checking there isn't a cunning way I can get my km/h clocks to read in mph before I go to this hassle.
The other problem in any case is the mileage it reads and making it the same (or as near as I can) to the true mileage of the car - which is about 10 - 15% higher than it should be anyway!
posted on 6/12/06 at 12:20 PM Reply With Quote
Can you not create a clock face in MPH on your PC, print it out and then just cover the one you have. There's a few people on here who have done just that.
Phil
Or even go to a bike breakers and find a speedo dial. Any one will do as long as it is a similar size and goes up to the required MPH. A set of broken clocks shouldn't set you back too much if anything at all.
[Edited on 6-12-06 by Hellfire]
hobbsy
posted on 6/12/06 at 12:30 PM Reply With Quote
On an R1 the speedo is a digital LCD display. The tacho is the only analogue display so a new dial doesn't work. I could put a sticker over the km/h bit but it would look a bit pikey and I'd still need a speedo healer to get it to read correctly.
chockymonster
posted on 6/12/06 at 04:06 PM Reply With Quote
With the main switch on so the clocks are powered up try and hold down the select and reset buttons for 3 seconds.
That changes it on mine.
