Author: Subject: trumpets
dilley
posted on 7/1/07 at 01:23 PM Reply With Quote
trumpets
Why are they different lengths?
Andrew.
indykid
posted on 7/1/07 at 01:26 PM Reply With Quote
for playing different music?
on a more serious note, by using different length trumpets alters where peak power is in the rev range or something to that effect.
tom
DIY Si
posted on 7/1/07 at 01:31 PM Reply With Quote
They are different length for different inlet tract lengths. This alters the frequency at which they resonate, and boost torque. Often useful for filling in holes in the torque curve or boosting peak torque. Oh, they also smooth the airflow into the carbs/bodies and aid overall power because of this.
Sun Tzu, The Art of War
dilley
posted on 7/1/07 at 01:32 PM Reply With Quote
I have 2 longer yhan the other 2, it doesnt make sense to me, I could understand if they were changed as a set.
G.Man
posted on 7/1/07 at 01:33 PM Reply With Quote
Longer gives more bottom end/mid range torque..
Shorter gives more top end.. in a nutshell..
Its a bit more complex than that, profile airbox design, position of filter and/or intake relative to trumpets..
I believe some blown engines use different length trumpets within a plenum to balance the airflow... but that is beyond my level of knowledge...
Opinions are like backsides..
G.Man
posted on 7/1/07 at 01:34 PM Reply With Quote
the 2 inner ones can be different to the 2 outer ones on a few bikes I have seen..
What bike is it? as some bikes also changed trumpet lengths and bores on different model years and you may have received a mix n match set..
LOL
dilley
posted on 7/1/07 at 01:40 PM Reply With Quote
Its a blackbird, its all running fine, I am just curious.
RazMan
posted on 7/1/07 at 02:10 PM Reply With Quote
The Duratec V6 uses two lengths of inlet tracts which are opened by a butterfly mechanism above 4000 rpm to boost the top end torque and closed to give more bottom end.
Raz
ChrisGamlin
posted on 7/1/07 at 03:05 PM Reply With Quote
I suspect they use different length tracts on the inner ones so that they can spread out the torque characteristics by having two cylinders producing more torque at lower rpm, and the other two slightly higher, rather than one slightly larger peak but only at a single rpm.
Also the two inner cylinders generally run hotter than the outer ones due to having another hot cylinder on both sides, to the extent that they run different fuel mixture settings on the inner two (certainly on the injected R1) so maybe that also has a bearing on it.
G.Man
posted on 7/1/07 at 03:19 PM Reply With Quote
chris is spot on, the R1 has to have richer jets on the middle 2 cylinders to balance the heat...
I think the longer trumpets MIGHT be for the 2 inner cylinders, maybe due to the shape of the airbox..
You will need to look at the owners manual to make sure... Haynes do one for the blackbird which should cover it
DIY Si
posted on 7/1/07 at 05:27 PM Reply With Quote
Yup, the longer two live in the middle, as Chris said, to spread the torque out a little. It helps level out spikes in the power curves.
roadrunner
posted on 7/1/07 at 08:09 PM Reply With Quote
So why is it better to fit an air box on bike carb's.
DIY Si
posted on 7/1/07 at 08:39 PM Reply With Quote
You can then tune the inlet even more to a particular rev range. It's an extension if the trumpet idea basically. It gives a bigger volume of air that is matched to a rev range to give a little positive pressure to the carbs. Again, used to fill holes in the torque curve.
ChrisGamlin
posted on 7/1/07 at 09:31 PM Reply With Quote
Yep, if (and its a big IF) you can get the airbox the right size and shape, you can start getting the effect known as pulse tuning where the resonance (ie timing of the pulses) of the air coming into the airbox coincide with the inlet valves opening on the engine, so you get a mini supercharging effect. Its only small, maybe worth a few horsepower on a bike engine, but if you get it wrong it can have the opposite effect and almost cause a negative pressure so less air enters the cylinders than it would without the airbox.
Running without an airbox has its pitfalls too though, because you're sucking in hot air from the engine bay, and also sucking in quite turbulent air especially if the air filter sticks out the bonnet.
smart51
posted on 7/1/07 at 10:35 PM Reply With Quote
Pulse tuning of an airbox (and all airboxes do this) adds a small positive pressure at the tuned RPM and at half that speed and a quarter of that speed. In between these you get negative pressure which worsens torque. the effect is slight but can be useful to flatten a spike or fill in a dip in torque.
My R1 engines both have fairly low acceleration up to 5000 RPM when suddely they take off. By tuning may airbox to 4500 RPM, the power now rolls on gradually from 4200 to 5000 RPM. It also sounds happier at full throttle in the range that it did before.
If trumpet length does the same thing then perhaps you could use it to cancel the dips caused by the airbox tuning, just leaving you with the primary airbox resonance.
Phil.J
posted on 8/1/07 at 04:36 PM Reply With Quote
Have a look on the Jenvey website. They have a very handy theory page explaining this and giving advice on the correct trumpet length/ throttle body diameter for each capacity engine.
Phil
ChrisGamlin
posted on 8/1/07 at 07:43 PM Reply With Quote
Sorry yep, I forgot to mention that its at a specific rpm so I guess all airboxes will do it at some revs, its getting it to pulse at the right revs thats the tricky bit.
