Author: Subject: Fireblade Clutch Cable
Avoneer
posted on 9/1/07 at 10:06 PM Reply With Quote
Do most folk start with an original item?
Just thinking of getting the best fix at the engine end.
Ta,
Pat...
posted on 9/1/07 at 10:08 PM Reply With Quote
Yep, original blade cable is long enough and can be used.
Phil
Avoneer
posted on 9/1/07 at 10:13 PM Reply With Quote
Cheers!
Just trying to get the last few bits before locking myself in the garage for a few long long nights and weekends!
Pat...
ChrisGamlin
The one Westfield supply for the Megablade is based on a Mk3 Cortina / Mk2 Escort I think, might be worth a look at the local factors.
bigrich
posted on 9/1/07 at 10:39 PM Reply With Quote
the standard sierra cable can be used with a couple of flats filed onto the clutch end nipple and a ring end grubscrewed onto the pedal end
ReMan
posted on 9/1/07 at 11:56 PM Reply With Quote
Built from scratch using inner and outer from the roll (MK).
Solder nipple at engine end and screw on at pedal end.
Broke first day!
Re soldered with plumbing flux and a bigger flange, OK since.
