adriane
| posted on 23/1/07 at 01:55 PM |
SVA Camber,toe & Damper settings
Hi there
I have an MK Indy with a Hayabusa engine and am completing the build. I will need to go for SVA so can any one tell me the settings for the camber,
toe,dampers, tyre pressure and any other setting I will need.
Adrian
zxrlocost
| posted on 23/1/07 at 02:17 PM |
front tyres pumped up 30psi
after 18psi
you need to drive your car and see if it self centres first
| posted on 23/1/07 at 02:19 PM |
SVA settings are basically to encourage self-centering. Toe-out and over-inflated tyres help....
Not a good idea if you're driving to the test though..... Best to have a little toe-in and 20Psi for driving to the station then adjust when you
get there.....
Dampers less critical- I'd start on the softest settings then firm it up with time.
Mark Allanson
| posted on 23/1/07 at 07:16 PM |
The SVA examiners are well aware of the self centring problems, and if they suspect a bodge, you will fail.
chockymonster
| posted on 23/1/07 at 10:38 PM |
Which is funny, mine didn't even drive mine at sva
