Author: Subject: what else do i need ?
andy o
posted on 30/1/07 at 07:39 PM Reply With Quote
if i were to fit a bike engine in kit what else do i need apart from engine /box ie
loom/ecu etc?
jacko
posted on 30/1/07 at 07:49 PM Reply With Quote
Prop shaft --money spare parts for the gear box
only joking
where is hellfire
[Edited on 30/1/07 by jacko]
posted on 30/1/07 at 08:31 PM Reply With Quote
Fuel pump....
Sensors (water temp etc) if EFi....
Lightweight passenger
[Edited on 30/1/07 by BenB]
iiyama
posted on 30/1/07 at 08:38 PM Reply With Quote
exhaust, possibly dry sump depending on what you wanna do with finished car and engine fitted, oil cooler, rad, fuel pressure regulater if FI.
If its broke, fix it. If it aint broke, take it apart and find out how it works!
nitram38
posted on 30/1/07 at 09:08 PM Reply With Quote
Power commander, CAT and lambda wideband sensor and gauge, plus laptop.
[Edited on 30/1/2007 by nitram38]
ayoungman
posted on 30/1/07 at 10:36 PM Reply With Quote
a few spare clutches, oh some more money for an engine rebuild after a couple of years !
"just like that !"
posted on 31/1/07 at 12:38 PM Reply With Quote
loom/ecu etc?
That really depends on which bike engine you decide to buy and how easy you want the install to be. For instance, if you want to use the original bike clocks instead of after-market stuff, it's easier to source an engine which includes the clocks. Also as has been mentioned, you might want the fuel pump (which are sometimes mounted in the fuel tank, depending on type of engine) and the fuel sender.
Best bet would be to decide which engine you want to use and then ask what specific parts you'll need.
Phil
