Author: Subject: Hayabusa Sprocket
iiyama
posted on 11/2/07 at 11:09 AM Reply With Quote
Hayabusa Sprocket
Simple question really....how the hell do I get it off??
Obviously a 32mm nut to undo, is it just a question of brute force and ignorance? Or is there something else to remove/relieve first?
Ta!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
richard thomas
posted on 11/2/07 at 11:13 AM Reply With Quote
can't remember anything untoward...just need to stop the engine spinning.
iiyama
posted on 11/2/07 at 11:38 AM Reply With Quote
Done that, but it wont shift. Using a Makita 14.4v impact wrench, maybe its just not man enough......
richard thomas
posted on 11/2/07 at 11:47 AM Reply With Quote
don't remember mine being so tight...is there a locking tab?
iiyama
posted on 11/2/07 at 11:49 AM Reply With Quote
Ah....there is what looks to be some silver foil, (its that thin!), around the threads.....not sure how to get it out though....prise it??
posted on 11/2/07 at 11:55 AM Reply With Quote
they are a bugger to get off in general. I got the first one off an engine, now i need one off a new engine and its stuck like STAB.... very hard when its not in the bike. My impact driver did nothing, and a long bar had too much leverage to stop the engine spinning.
iiyama
posted on 11/2/07 at 11:59 AM Reply With Quote
So the answer was.............???
richard thomas
posted on 11/2/07 at 12:06 PM Reply With Quote
I seem to remember that it was just a nylock nut and the speedo sensor thingy - i undone it when it was still in the bike so that may explain why it was easyish...
iiyama
posted on 11/2/07 at 12:11 PM Reply With Quote
Got the speedo sensor off, that was just an Allen bolt, although bloody tight!
iiyama
posted on 11/2/07 at 01:52 PM Reply With Quote
OK, think I see the problem. Torque on the nut is, (or should be!), 145nm. The Makita only knocks out 140nm at best, so on a 32mm nut its probably a lot less.
Have to think again on how Im gonna get it off!
ChrisGamlin
posted on 11/2/07 at 07:15 PM Reply With Quote
A proper air impact wrench is what you need really, if youve got the air capacity it should kick out well over 200ftlb.
Alternatively Halfords sell a 12v fag lighter impact wrench for about £20. It doesnt work in the same way as a normal impact gun in that it seems to have some kind of centrifugal weight in it and it spins up for 2-3 seconds before giving a single "impact", then repeats this process. Its not great for speedy work like wheel nuts but my one does seem to give the nut a fair old whack and I think it claims something like 200ftlb release torque so might do the job.
ChrisGamlin
posted on 11/2/07 at 07:18 PM Reply With Quote
BTW iiyama, I only live about 30 miles from Southampton (near Bordon) and work at Hook on the M3, so if you want to pop up and borrow it to give it a try you're more than welcome.
Chris
iiyama
posted on 11/2/07 at 07:22 PM Reply With Quote
Small world! Have done some work up in Bordon!
Thanks for the offer, Ill bear it in mind if I get stuck!
ChrisGamlin
posted on 11/2/07 at 07:44 PM Reply With Quote
I actually live in Lindford which is a mile or two away from Bordon (thankfully )
Ive also got an compressor and air impact wrench so if you really get stuck you could always put the engine in the back of the car and bring it up one weekend.
Chris
iiyama
posted on 11/2/07 at 07:48 PM Reply With Quote
LOL! Dont think the Mrs would be too chuffed!
Very generous offer though Chris, thanks
ChrisGamlin
posted on 11/2/07 at 08:01 PM Reply With Quote
What she doesn't know..... etc etc
iiyama
posted on 12/2/07 at 07:42 AM Reply With Quote
Buddy you should know women better then that! Or maybe its just my women.......
Anyhow I have a van, so the car is surplus for lugging things around!!!!!!
ChrisGamlin
posted on 12/2/07 at 06:15 PM Reply With Quote
I do trust me, hence the comment "What they don't know.....", ie don't tell her!
