Author: Subject: Battery
iiyama
posted on 12/2/07 at 08:41 PM Reply With Quote
Battery
Looking to fit an Odessey battery. Simple question, which one??
ps not sure if this should be in the electrical section, but as its a Busa thought Id try here first!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
novacaine
posted on 12/2/07 at 09:15 PM Reply With Quote
if it were a CEC i would say go for a yellow top optima but that may be a bit of an overkill for a BEC
could consider it, unless your engine setup demands a 6v feed that is...
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
RazMan
posted on 12/2/07 at 09:46 PM Reply With Quote
The smallest one of the range (PC545 I think) is used in Ultimas and they will start a 6 litre Chevvy without any fuss - I reckon it should be ok for a Busa
[Edited on 12-2-07 by RazMan]
Raz
chockymonster
posted on 12/2/07 at 10:29 PM Reply With Quote
Got a PC525 in mine.
iiyama
posted on 12/2/07 at 10:32 PM Reply With Quote
Cheers peeps!
Richard Quinn
posted on 13/2/07 at 11:06 AM Reply With Quote
Apologies in advance for the hijack!
Would any of the Oddysey range be suitable for a race car (CEC) with no alternator that will run for up to 5 x 5min heats on any particular day?
