Author: Subject: help needed
d8mok
posted on 20/2/07 at 08:18 PM Reply With Quote
help needed
just a few questions....
is there a seal or something that can leak between the propshaft flange and diff flange on a english back axle??
how do i fill the diff with oil? cant get the plug undone?
thanks
[Edited on 20/2/07 by d8mok]
Chippy
posted on 20/2/07 at 10:47 PM Reply With Quote
There is no seal between the two flanges, although it has been known for oil to work through the splines on the diff. If that is a problem clean the diff flange/nut/washer and apply a liberal coat of liquid gasket to them, that "should" cure it.
As far as I am aware the "only" way to fill the diff is through the filler plug, (think thats why its called that, ) so you will need to get it out someway, bit of heat may help. HTH Ray.
