ChrisGamlin
| posted on 16/7/03 at 11:06 AM |
FOR SALE : Blade clocks / Yellowbox / SPA digital oil pressure & temp gauge
I'll put this in the for-sale section too, but its mainly BEC related so is going here too
SPA digital oil pressure/temperature gauge (1 yr old, model DG201B) with senders. - £100 (£155 new)
SPA Gauge webpage
Yellowbox speedometer re-calibration module (1yr old) - £45 (£70 new)
'99 RRX Blade bike clocks £70 (Feck knows new, £100 from breakers!)
Or £200 the lot
e-mail me or post back if ur interested in anything
[Edited on 16/7/03 by ChrisGamlin]
suparuss
| posted on 16/7/03 at 03:49 PM |
what is a Yellowbox speedometer re-calibration module?
ChrisGamlin
| posted on 16/7/03 at 03:57 PM |
Yellowbox Website
Basically it plugs into the bike loom between the speedometer sensor and the speedometer display, and allows you to adjust the signals so that the
speedometer reads correctly.
For example, when riding a Fireblade bike, 11000rpm in top gear will be around 170mph, whereas in the BEC kit car, it will only be around 120mph due
to the different gearing. However, the speedo will still think its in the bike and so shows your speed as 170mph when its really 120mph. The Yellowbox
allows you to remove this error by adjusting the signal that the sensor sends to the speedometer.
Chris
Jasper
| posted on 16/7/03 at 07:39 PM |
Hey Chris, what you replacing it with?????
ChrisGamlin
| posted on 16/7/03 at 08:13 PM |
Digidash I think, although I spoke to ETB this afternoon and they arent getting new stock until mid August, so might not be able to sell the clocks /
gauge until then (although I dont use the speedo anyway so the Yellowbox can go!)
Chris
suparuss
| posted on 17/7/03 at 05:41 AM |
cool, im interested in the yellow box thingy, should work for a bike engine with a porsche speedo right? should be the same principles anyway.
drop me an email with your addy and ill send you a cheque.
Russ.
ChrisGamlin
| posted on 17/7/03 at 09:59 AM |
What's your email addres Russ? LOL.
I've provisionally sold it to someone else on the list, but you are second in line if that falls through.
Im really not sure on the Porsche speedo TBH, you'd need to find out whether they work mechanically or electronically, and if electronically,
what feeds etc they have. Have a look on the Yellowbox website (above), I seem to remember there being something on there regarding car speedos and
bike speedos.
Chris
suparuss
| posted on 17/7/03 at 03:08 PM |
hehe thought me mail was in me profile.
i have the speedo already, its is electronic, and it is most likely hall effect, cant see it being the old kind cos its from a fairly new car.
Me mail is dmw74@hotmail.com if the other guy doesnt want it. im in no hurry anyway.
cheers,
Russ.
