welderman
posted on 20/3/07 at 10:08 AM |
919cc to 893cc blade swop
would i notice a performance drop if i changed from 919 to 893 blade engine and are they the same block just smaller cc.
Thank's, Joe
I don't stalk people
shortie
| posted on 20/3/07 at 10:41 AM |
Why do you want to swap??
welderman
| posted on 20/3/07 at 10:53 AM |
selector forks need sorting and poss gear box, so thinking of a quick fix for summer and then fix the 919.
Thank's, Joe
shortie
| posted on 20/3/07 at 11:17 AM |
I would guess the 919 is a bit quicker but not loads of difference
scotlad
| posted on 20/3/07 at 11:52 AM |
Not much in it methinks. Power delivery a bit sharper on 893cc probably. Hmmm which reminds me i suppose i should sell my old 893 engine. *sigh*
Jon Ison
| posted on 20/3/07 at 01:02 PM |
893 engine, whos selling ?
u2u me if you are.
scotlad
| posted on 20/3/07 at 02:44 PM |
U2U's sent
ChrisGamlin
| posted on 20/3/07 at 06:04 PM |
Yep there's bugger-all real world difference in performance once you're on it, just a bit fatter mid-range on the 919.
Don't forget though that the selector drum is reversed on the 893 so your gear change will be back to front if connected up as is. Also
there's no speedo sender mounted in the 893 block so if you're using blade clocks you'll need to work out a remote way of triggering
the sensor.
Chris
welderman
| posted on 20/3/07 at 08:27 PM |
so not a bad solution then, i have a light sensor for my speedo so am ok there and as for mid range the turbo should sort that.
Thank's, Joe
ChrisGamlin
| posted on 20/3/07 at 08:39 PM |
Gearchange reversal is a concern though if you can't easily mod your linkage and you're used to it being in the current direction. One
instinctive "up" change at 12krpm and you'll be after another engine (probably a 919 )
welderman
| posted on 20/3/07 at 08:46 PM |
. I know, boom. But just ordered one of those cable tec push pull rod thingy(tec wording) so should be able to sort it. I HOPE .
Thank's, Joe
garage19
| posted on 20/3/07 at 11:09 PM |
There are a couple of fireblade breakers speacilists like "The fireblade Shop".
Just give one a bell and buy the bits you need.
Changing the selector forks or even gearsets is a piece of wee wee on blade engine!
