roadrunner
| posted on 28/3/07 at 07:33 PM |
zx9r bolt sizes
As above, does anyone know the thread size for the 12mm bolts.
Brad
Wadders
| posted on 28/3/07 at 07:42 PM |
Most are metric fine, so with a 12mm head i'd hazard a guess at 8mm thread. Which bolts do you mean exactly?
Al.
Brad
roadrunner
| posted on 28/3/07 at 07:48 PM |
The two end mounting bolts.
Brad
mistergrumpy
| posted on 28/3/07 at 07:51 PM |
U2U sent
tks
| posted on 28/3/07 at 08:10 PM |
mhh
if the size of the bolts is known
please post..
its valuable info
Tks
russbost
| posted on 28/3/07 at 08:17 PM |
M10 Fine I believe
Wadders
| posted on 28/3/07 at 09:03 PM |
You believe right, zx9 engine mounting bolts are indeed M10 fine
Originally posted by russbost
M10 Fine I believe
roadrunner
| posted on 28/3/07 at 09:10 PM |
The two long bolts on the gearbox are 10mm, but when i tried one in the top mounting position, they just pass straight through.
  front mounting points
It's the one on the left.
[Edited on 28/3/07 by roadrunner]
| posted on 28/3/07 at 11:18 PM |
Mine's like that. M12 goes through and a nut on the back.
mackei23b
| posted on 30/3/07 at 01:42 PM |
I'm sure that m12 was too big for me
(I'm sure M11 is a standard size in Japan, but not Europe). I sleaved the hole and used M10.
Ian
[Edited on 30/3/07 by mackei23b]
roadrunner
| posted on 30/3/07 at 06:14 PM |
Bought some M12's today, fit perfectly, so to recap, zx9r 1998, M10 bottom bolts, and M12 top bolts.
Cheers fellas.
