Author: Subject: Blade fuel pump orientation
andrew.carwithen
posted on 29/3/07 at 08:20 AM Reply With Quote
Which is the inlet and which is the outlet port on a carbed 'blade fuel pump? (i.e. say with the ports facing you?)
Andy.
ReMan
posted on 29/3/07 at 09:04 AM Reply With Quote
I don't remember tyere being any markings, safest way I guess would be to test it, power it up and pump some liquid to be sure?
shortie
posted on 29/3/07 at 09:31 AM Reply With Quote
This shows how mine is setup and works fine.
[img][/img]
andrew.carwithen
posted on 29/3/07 at 09:41 AM Reply With Quote
So, to confirm, looking at your picture, Shortie, the braided fuel line is the one going to the carbs and the rubber line with in-line filter is the one going to your fuel tank?
Andy.
Gav
posted on 29/3/07 at 10:57 AM Reply With Quote
I know if you look at mine face on with the wires on top, the inlet is on the right, outlet on the left
Edit: um bugger i wonder if mines connected up wrong as it looks wrong by that pic, ive definatly had it pumping though and iirc their is a one way valve in the pump so its not as if i could of connected the power on the wrong way round!
[Edited on 29/3/07 by Gav]
shortie
posted on 29/3/07 at 12:17 PM Reply With Quote
I suspect it does not matter which way round it is fitted.
Rich.
posted on 29/3/07 at 12:35 PM Reply With Quote
I bet it does....
Can't you power it up (pp3 9v battery if not fused) and just feel which tube is sucking and which is blowing???
andrew.carwithen
posted on 29/3/07 at 03:04 PM Reply With Quote
Originally posted by BenB
I bet it does....
Its actually wired into the loom and so does operate when the ignition switch is turned on.
Even so, I've dangled a piece of tissue paper in front of each port to see which way it flutters but there's no discernible movement, even though the pump's buzzin' away like a good 'un.
Could it be a case of the pump needing to be primed with fuel first before it effectively works?
Andy.
Jon Ison
posted on 29/3/07 at 03:53 PM Reply With Quote
yup, you will feel nothing till you prime it.
andrew.carwithen
posted on 4/4/07 at 09:45 PM Reply With Quote
Rather than having fuel spraying out all over my engine bay, is it ok to use a small quantity of water (albeit very briefly) to prime pump to determine inlet and outlet ports or would it damage the pump?
Andy.
