Author: Subject: Best Fuel Pump for R1 Engine
posted on 6/4/07 at 08:02 PM Reply With Quote
Silly question, I know, but is it simply a case of using the OEM bike fuel pump?
posted on 6/4/07 at 08:06 PM Reply With Quote
If you have it, then that would be the easiest/best option.
Phil
posted on 6/4/07 at 08:18 PM Reply With Quote
Yep - all sorted out!
Great chap to speak to - very helpful.
I ended up buying a couple of sets of Radial Calipers from him that I intend playing with (probably without success, but what the hell... !).
posted on 6/4/07 at 09:28 PM Reply With Quote
Yup. Best to use the bike pump unless its an in tank jobby in which case something else might be easier....
ChrisGamlin
posted on 6/4/07 at 09:47 PM Reply With Quote
I was going to say, is it carbed or injection? If the latter then the R1 in tank pump isnt the easiest thing to fit due to needing a matching flange welded into the tank, so an inline Bosch pump would be easier. I used one specced for a Rover/TVR V8 install, but others have used a similar pump from a Calibra/Vectra I think, there was a thread within the last month or two that had details in it (posted by Jim Giblett I think)
nitram38
posted on 6/4/07 at 09:50 PM Reply With Quote
Because of the flange issue on the R1 pump, I am going to use a kwaka zx10 pump. They are bolt in and cost about 25 notes on fleabay.
speed8
posted on 6/4/07 at 10:21 PM Reply With Quote
I used the 03 R1 pump fitted to the bottom of my tank. I've only used it in the garage but it seems to work ok and doesn't leak!!
