Flick
| posted on 11/4/07 at 09:29 PM |
blade troubles
hi
just wondered if anyone could help. Got a ST with a 98 blade engine. The revs upto about 7k are all lumpy and bumpy. After 7k they go all right.
Any ideas
worX
| posted on 11/4/07 at 09:33 PM |
could maybe do with a bit more info...
Is it fitted with a dynojet kit? Sausage filter? etc.
From this you could probably start eliminating things like too much air flowing in (and the like)...
cheers,
Steve.
Flick
| posted on 11/4/07 at 09:35 PM |
Sorry
No its not fitted with a dynojet kit or sausage filter. Its just got sock filters and i thinks the jets have been upped from 115 to 132 if that
helps
Just forgot to mention its been running fine with this set up for six months now its just happened today
[Edited on 11/4/07 by Flick]
worX
| posted on 11/4/07 at 09:52 PM |
well I am only speaking from passed on information so take what I write with a pinch of salt, but I was led to believe that sock fiters are Not the
best with the Blade engine.
I understand that it has been running fine for 6months...
the other thing to check is if your main air jets have been correctly blocked off - it may be one of these things that is now letting in too much
air?
in case you need to know which one should be blocked off when fitted with larger main jets, check here:
http://www.locostbuilders.co.uk/viewthread.php?tid=57917
hth
higgsti
| posted on 11/4/07 at 10:07 PM |
try putting some fuel injector cleaner in the petrol stp/redex happened to me on megablade and this cured the problem.also check leads an plug caps
