zxrlocost
| posted on 21/4/07 at 07:18 PM |
seized throttle blade engine
hi my throttle mechanism moves a few mm before it seizes up
before I remove the carbs any ideas anyone
you can barely see down the gap let alone get anything down there
[Edited on 21/4/07 by zxrlocost]
RichardK
| posted on 21/4/07 at 07:53 PM |
Maybe the cable itself, you have got a decent earth haven't you
Just thought I would mention just in case it's been earthing via the throttle cable and has now welded itself inside the outer sheath!
Regards
Rich
Gallery updated 11/01/2011
smart51
| posted on 21/4/07 at 08:21 PM |
turn the rotor that the cable fastens to, to see if the throttle will rotate and so if its the cable thats stuck.
