Author: Subject: Outter clutch plate slipped off??
skidude88
posted on 23/4/07 at 01:28 PM Reply With Quote
Was hoping to go for 1st shake down yesterday with new engine fitted. Discovered I'd no clutch.
Took the case off and the outer clutch plate had somehow slipped off over the splines
Anyone seen this before?
I can't see how its happened as the Clutch Press plate was on tight.
Just concerned if its happened once it could happen again??
Early MK de-Dion CBR1000 FJ-FP.
tks
posted on 23/4/07 at 02:23 PM Reply With Quote
check with the cover of after repair that your pedal travel isn't to much...
you will need to put a limitter on.
Tks
