Author: Subject: Hot cdi and no spark
roadrunner
posted on 29/4/07 at 07:08 PM Reply With Quote
I've got all my wiring done now, thought i would see if i had a spark.
Tried a spare spark plug, no spark, i crossed the start/stop switch, red to brown/white, so took out the brown/white, tried again, no spark, but when i put the brown/white wire back in ,a spark, so as i touched the brown/white to the red i got lots of sparks, but no spark when permanently spliced, also, a hissing noise, coming from my cdi unit, and it got very hot, please dont say i've buggered that as well, help please.
Brad
rayward
posted on 29/4/07 at 07:17 PM Reply With Quote
sorry but it sound like you;ve killed the CDI.
do you have a wiring diagram for it? if your stuck i could pop over and give you a hand
Ray
[Edited on 29/4/07 by rayward]
roadrunner
posted on 29/4/07 at 07:36 PM Reply With Quote
Yes, i do have a wiring diagram, but theres not alot to change, i've spliced the stand switch, and the clutch switch, a feed from position two on ign to start stop switch, connected start/stop wires together, 100ohm resister between brown and white, on original ignition, then fed the car loom ignition to the starter relay, the only thing i can think of , is the wiring at the start/stop switch.
roadrunner
posted on 29/4/07 at 07:44 PM Reply With Quote
On the wiring diagram, there is two switches, one stop switch, and one start switch, these are fed buy three wires, red wire and brown/white to the stop switch, and red and black/red to the start switch, i have just jumped the red to the brown/white, is this correct.
roadrunner
posted on 29/4/07 at 09:39 PM Reply With Quote
It looks like i've connected the clutch switch wires wrong, i will try tomorrow and let you all know.
cossiebri
posted on 30/4/07 at 02:15 PM Reply With Quote
That's how i've got mine
If it doesn't fit MODIFY it!!
Cheers BriF
roadrunner
posted on 30/4/07 at 07:50 PM Reply With Quote
Yes, but yours does'nt spark either Bri.
cossiebri
posted on 1/5/07 at 07:06 PM Reply With Quote
Have got a bike leccy 'guru' coming round on sat morning.Will let you know what goes where? (IF it start's!)
Cheers BriF
roadrunner
posted on 1/5/07 at 08:15 PM Reply With Quote
Earthed the clutch switch, still no spark.
