Author: Subject: "Joining" Drive Shafts
posted on 2/5/07 at 01:02 PM Reply With Quote
Now that I know my standard Caterham derived drive-shafts won't fit into the Freelander Diff that I intend to run, is it simply a case of buying a couple of Freelander shafts, cutting them in half and joining the inner spline end to the lower spline end of my Caterham shafts (accurately of course!)?
I had looked into getting a pair of bespoke drive-shafts made, but that would cost £££££££££££££.
posted on 2/5/07 at 01:14 PM Reply With Quote
Yup. Mostly done by chopping and welding.... Just make sure its done by someone who's the dog's doodahs at welding and has a powerful enough welder..... Driveshafts snapping isn't a nice proposition!!
posted on 2/5/07 at 01:17 PM Reply With Quote
I know such a welder!
Fatgadget
posted on 2/5/07 at 01:42 PM Reply With Quote
There are companies around that make bespoke drive shafts for not too much money.
James
posted on 2/5/07 at 02:35 PM Reply With Quote
I think it's generally done by sleeving the two pieces.
As for getting them made... there's a guy on here who some people (Flakmonkey) rave about.
Seem to remember they're about £70 each shaft.
HTH,
James
RazMan
posted on 2/5/07 at 06:45 PM Reply With Quote
GB Engineering did a good job of mine. I haven't got the number to hand but if you do a search .....
Raz
posted on 2/5/07 at 07:27 PM Reply With Quote
you would be looking at £200 for bespoke by the time delivery is added on. Sierra shafts are nearly free, i saw some freelander ones sell for £70 pair delievered. That would save you about 130 but cost you some materials and a few evenings work. Ideally you would turn the shafts to the same diameter in a lathe to aid accurate sleeving. Then you just need to consider the quality differences. I believe the custom ones are not just normal ones sleeved but entirely new shafts, so they would be lighter etc.
Pays your money and takes your choice!
