imp paul
| posted on 13/5/07 at 08:38 AM |
any thorts zx12 r ram pipes on tbs
hi I'm having problems with not much room in the back of the imp .so im thinking of not having the ram pipes on at all .and fit a low itg type
filter will it make any difference if at all ? does eny one on here run without ram pipes and if so is all OK ? thorts please lads its on TBS
[Edited on 13/5/07 by imp paul]
mookaloid
| posted on 13/5/07 at 09:11 AM |
I would have thought that you will really need some sort of curved ram pipes even if they are only short ones. The airflow won't be as good
aroundthe sharp corners into the carbs/TB's if you have nothing at all. This would lead to less power/torque.
Mark
russbost
| posted on 13/5/07 at 09:47 AM |
Can't speak for the zx12 specifically, but on my Zx10's if you remove the airbox they run like a complete bag of poo - ridiculously weak,
won't rev out, popping banging etc. - quite incredible difference. You might get away with a very short ram tube, but would expect to need to
rejet.
imp paul
| posted on 13/5/07 at 01:48 PM |
thanks to all
hi mark and how are you hope your ok .as for mr gr was his imp racing ? and if so how did it go? also need to send you the clocks ups sorry i will get
them off to u mate if you still want them? hows the gsxr lump is all good ? iv not got much room with the ram pipes on so they will have to go to give
more room so i can lift the engine a bit more due to the sump being 3inc of the deck
