mistergrumpy
| posted on 26/5/07 at 09:21 AM |
What Gauge Gear Selector
What gauge steel have people used to make gear selector mechs? I was thinking that the 1-1.2mm stuff I have might be a bit thin and start bto deform
whereas solid stuff might twist unless its drilled down its centre.
daviep
| posted on 26/5/07 at 01:16 PM |
I'm sorry I 'm not really understanding what the question is? Are you asking what wall thickness of tube to use ? What is solid stuff and
why would it twist if it wasn't drilled down it's centre.
Sorry to be of absolutely no help
mistergrumpy
| posted on 26/5/07 at 03:47 PM |
No worries mate, ignore me. I'm thinking out loud again I think. Yes I was looking at what gauge to use. I thought that solid steel was more
prone to twisting than 'gun drilled' steel or so I've read and what with there being a lot of torque applied to the gear change
mech, i.e. the jiggery pokery bit between the gear knob and gear change on the engine I wondered what gauge was best
zxrlocost
| posted on 26/5/07 at 06:32 PM |
how much force are you planning on applying?
a good one is some threaded bar with some sleeve bar from b and Q
bodger
| posted on 26/5/07 at 07:27 PM |
On the subject, where can you get the splined part of the selector mechanism from ?
adithorp
| posted on 26/5/07 at 08:26 PM |
I used 8mm threaded rod brazed into thin wall steel tubing (8mm id) from B+Q Warehouse. I tried aluminium tube but it flexed too much unless you use
larger diameter.
Adrian
mistergrumpy
| posted on 26/5/07 at 11:35 PM |
Ah. Tis B&Q stuff I have. Guess that'll do then?Thought it might be a bit too thin.
mad-butcher
| posted on 27/5/07 at 07:14 AM |
which part of the splined mechanism do you mean, the shaft thats built into the engine or the gear change arm, if it's the arm I think most jap
bikes use the same spline
Tony
matt_gsxr
| posted on 28/5/07 at 03:36 PM |
splined gearchange
I remember this (vaguely) from a while ago.
From memory Suzuki use a 14mm spline (maybe Aprilia too).
The others use a 12mm spline.
There was a posting from someone who had bits for this a while ago, and so might be able to help. Look up rick1962uk
on these pages. He seems to stock these bits.
The other solution is to just pick up a gear change arm, about £8 on e-bay.
Matt
