Author: Subject: hayabusa fuel gauge
desyboy
posted on 27/5/07 at 04:17 PM Reply With Quote
hayabusa fuel gauge
Could anybody please tell me what type of sender has to be fitted to an mk tank to get the fuel gauge to work on the hayabusa clocks.
cheers des
OX
posted on 28/5/07 at 03:40 AM Reply With Quote
i used the one that came with the bike and its part of the fuel pump
desyboy
posted on 28/5/07 at 12:31 PM Reply With Quote
cheers mate ,does that bolt into the tank like the r1
OX
posted on 28/5/07 at 03:20 PM Reply With Quote
it depends what year engine you get,mine was a 2003 and the sender is part of the fuel pump,it uses only one fuel line going to the t.b's as the pressure relief valve is in the pump.on the earlier models the fuel pump sits at the back of the throttle bodies ,martin made me a swirl pot for the bottom of the fuel tank and the pump fitted to that, i made a gasket out of pond liner . im not sure if the way i did it was the best way because i had problems getting it through the sva even with a power commander because i couldnt reduce the fuel pressure as easy
