Author: Subject: Where to get?
Pezza
posted on 31/5/07 at 09:43 AM Reply With Quote
Where to get?
Right, after a sump baffle for a 5JJ lump 2001 and some uprated clutch springs for my newly aquired engine.
Where have other people got theirs from?
Would prefer the sump baffle that doesn't need any drilling/tapping to be done.
Ben
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
zxrlocost
posted on 31/5/07 at 09:54 AM Reply With Quote
I never bothered with a sump baffle Ben but its up to you
the engine is still going strong with the new owner
smart51
posted on 31/5/07 at 10:42 AM Reply With Quote
I got my 4XV baffle through MNR. I'd bet they'd do a 5jj one for you. It is held on by being sandwiched between the block and the oil pickup pipe / oil transfer pipe / block drain pipe which are just bolted on.
ChrisGamlin
posted on 31/5/07 at 12:05 PM Reply With Quote
Contact Jonathon Rarity, he makes the CNC machine'd baffle plate (which I think Fluke Motorsport sell) and very nice they are too, fitted perfectly to my 5PW with no fettling at all.
As to clutch springs, have you done a Barnett spring conversion or are you still using the stock diaphragm spring? If the latter then I think your only real options are to double up on the standard diapragm spring, or to try and source a YEC (Yamaha Race team) uprated one.
[Edited on 31/5/07 by ChrisGamlin]
Coose
posted on 31/5/07 at 09:15 PM Reply With Quote
Jonathon Rarity's baffle plates can be found here.
Another thumbs up from me!
Re. clutch springs - my 5JJ has had well over 6000 miles of abuse with a standard clutch and is still ok! This includes many trackdays.....
Don't spend your money until you have to!
Spin 'er off Well...
StevieB
posted on 31/5/07 at 09:28 PM Reply With Quote
Will that fit a 5JJ engine?
I was not going to bother with a bafle, but I've been reliably informed that I need one...
ChrisGamlin
posted on 31/5/07 at 10:35 PM Reply With Quote
The one on ebay won't as its for the 04-07 engines, but contact Jonathon as he does ones for earlier engines too.
