Author: Subject: R1 Ratio's.... Got the Wrong Diff - Any Suggestions?
posted on 5/6/07 at 06:02 PM Reply With Quote
I have a 2006 R1 engine, no reverse box, 3.21 diff (Freelander), and am running 22.0 / 7.0 / 13 ACB10's on the rear.
So, thanks to Chris's Excel gizmo, I've established that I'll get:
69.9
85.9
100.6
116.4
129.9
139.7
Not the best really!
I'm guessing that's going to be a pig to drive.
B*gger - really annoyed about this as I was encouraged to go for the Freelander Diff by someone who should know better, so have coughed up £750 to buy a new one and Quaife ATB!
Check out the 'For Sale' section soon!
Any suggestions for a higher ratio diff? Doesn't have to be Ford as I'm willing to adapt driveshafts to suit. Must be LSD though.
[Edited on 5/6/07 by scootz]
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 5/6/07 at 07:28 PM Reply With Quote
at the 13750rpm redline
1st 76.3mph
2nd 93.6
3rd 109.6
4th 126.9
5th 141.6
6th 152.2
ratios are 1.512 primary
1st 2.533
2nd 2.063
3rd 1.762
4th 1.522
5th 1.364
6th 1.269
[Edited on 5/6/07 by cossey]
ChrisGamlin
posted on 5/6/07 at 07:35 PM Reply With Quote
I dont have the ratios for the 06 engine, but as cossey has listed them for you, you can pump them into the spreadsheet (in my avatar below)
ChrisGamlin
posted on 5/6/07 at 09:03 PM Reply With Quote
Id say 1st is a bit long which will make it a PITA to pull away, and unless you've got an enclosed body car (Phoenix / Fury etc) then you won't hit 140mph, not without a tail wind and downhill anyway!
The problem you have is that the Freelander only comes in that ratio I think, so you might need to change to a Sierra. Could you not go down to 21 / 7 ACB10s though?
Bob C
posted on 5/6/07 at 10:18 PM Reply With Quote
I have a 3.14 diff on a '98 R1 & pulling away is not too bad (admittedly I'm not the fastest off the line). Traffic is a bit of a 'mare though esp. an uphill queue to lights/roundabout.
I also have all the mechanics on rubber and a donut in the prop so I can get a bit of kangarooing, esp. when cold & I'm trying to go slow. I can only get round this by driving like a tool, which gets a bit wearing!
Bob
chockymonster
posted on 6/6/07 at 06:04 AM Reply With Quote
I have a 3.38 diff in my 2002 R1 and in my mind it's perfect but not an LSD. You can quaife ATB it though.
ChrisGamlin
posted on 6/6/07 at 08:47 AM Reply With Quote
04-06 engines have a slightly higher first gear than our earlier engines as well though, overall ratio for an 02 R1 is 3.95:1 compared to 3.83 for the 06 (~3% higher), and also have slightly less torque than earlier engines below about 7k which also won't help matters.
jimgiblett
posted on 6/6/07 at 09:17 AM Reply With Quote
By those calcs I would just stick a 3.62 in which will give you a max at close to 125 and a very reasonable 62 mph in 1st. The 3.62 sierra diffs are common as muck even LSD versions and at least you can be out driving rather than waiting for a 3.38 to materialise. If and when one turns up it si an easyish swap if Lobro'd
And like Chris says you may struggle to pull much more than 130 without some aero mods.
- Jim
smart51
posted on 6/6/07 at 09:55 PM Reply With Quote
its about 5.5 MPH/1000 RPM which isn't too bad. You can pull away well enough on that but you'll not have to be too timid.
road warrior
posted on 6/6/07 at 11:51 PM Reply With Quote
Hi Scootz
I would personally put in what you have and swap it out later if your not happy. I guess it depends on what you are using the car for but you have all good new bits so try them first.
I have and '06 engine and the ratios are a bit shorter than the 04-05. I have a muffett diff so I can change the ratio easily but I have run a 2.76 and it was ok. I run dunlop slicks which are 215/45/13 on the ratio chart.
There is a lot you can gain by spending a bit of time with your clutch pivot. Initially the car was a pig to get going but by moving the pivot closer to the pedal and fitting a clutch stop so that I could get more feel as to when the clutch would take up it transformed the car.
I have also ironed out a few bugs with the 'o6 engine so if you have any dramas give me a hoy.
Sonja
posted on 7/6/07 at 06:09 AM Reply With Quote
Thanks Sonja - we'll see how it goes.
