Author: Subject: Engine when hot makes a noise!!! HELP
tks
posted on 21/6/07 at 12:53 PM Reply With Quote
When my engine is hot it makes a ticking noise...
when i press clutch the noise goes away.
its in the gearbox.....
Dunno what happens if i put it in gear....
guess no noise.
anyone ideas..
Tks
ash_hammond
posted on 21/6/07 at 01:16 PM Reply With Quote
Clutch Release Bearing???
.: www.mac1motorsports.co.uk | www.m1moc.com :.
ecosse
posted on 21/6/07 at 01:45 PM Reply With Quote
Could be wear in the clutch basket, seen that b4, allows the plates to rattle a bit.
Alex
pewe
posted on 21/6/07 at 04:56 PM Reply With Quote
Agree with Alex. Seem to recall that the cushion springs in the friction plate used to rattle when they wore a bit. Don't know whether that applies to your configuration though. Cheers, Pewe
Coose
posted on 21/6/07 at 07:19 PM Reply With Quote
Don't worry about it. The cause is as-above!
One thing that can reduce it is to blance your carbs/throttle bodies as it causes uneven running, most noticeable at tickover, which in turn causes the clutch basket to vibrate. It won't do any harm though, but balancing will help your motor start easier too!
[Edited on 21/6/07 by Coose]
Spin 'er off Well...
posted on 21/6/07 at 10:21 PM Reply With Quote
Sounds to me like a badly adjusted clutch cable (too tight). Make sure you have some slack on the cable when not depressed.
dhollin3
posted on 22/6/07 at 09:10 AM Reply With Quote
If it is anything like my old Honda CBR600 then it could be the Cam chain tensioner. If it is a hydraulic one that isn't working correctly then this could cause the chain to whip a little. This was a common fault on the CBR but it doesn't really cause any long term problems, just an annoying noise.
tks
posted on 30/6/07 at 10:16 PM Reply With Quote
Thanxs guys!!!
sounds good, will try the clutch one...
is it possible that it could be a bend vork?????
will try the clutch tension...
Thanxs
p.s. this engine has cam drives sow no chain..also it has clutch springs/basket/steel/fiber plates design...
p.d. late reaction forgot to enabale email notification
[Edited on 30/6/07 by tks]
