Author: Subject: Max Power Engine Speed for SVA
Avoneer
posted on 23/6/07 at 12:10 AM Reply With Quote
What's the norm for the SVA form as IIRC this is what they base the noise level on, all be it a percentage.
I've put 8k ???
Pat...
robertst
posted on 23/6/07 at 12:38 AM Reply With Quote
IIRC it was 40% of max power? i.e. 2500 rpm for a pinto?
[edit:] didnt get the BEC thing.. anyway i think it was 40% of max power, supposing its a fireblade, max hp would come in at what, 10-12k rpm?
[Edited on 23/6/07 by robertst]
Tom
Avoneer
posted on 23/6/07 at 07:09 AM Reply With Quote
Sorry - didn't word it very well.
The SVA1 asks what RPM maximum power will be at.
I pressume this question is so that they can work out what RPM to do the noise test at.
So I wrote 8000 RPM.
Engine is a 919 'blade.
Pat...
mad-butcher
posted on 23/6/07 at 07:48 AM Reply With Quote
Pat
I would have thought 9 or 10 but these guys aren't that soft they know better than us what a bike engines revs to
Tony
smart51
posted on 23/6/07 at 08:05 AM Reply With Quote
Doesn't the 919 blade make max power at 10,500?
stevec
posted on 23/6/07 at 08:15 AM Reply With Quote
You should put the exact rpm as Honda states it.
If you try and blag the tester he will walk all over you.
russbost
posted on 23/6/07 at 08:44 AM Reply With Quote
"You should put the exact rpm as Honda states it.
If you try and blag the tester he will walk all over you."
Not entirely true, I put 10,000 down for my engines, IIRC Kawasaki state it at 11,000, I think you'll be lucky if you can persuade them that 8,000 is really peak power for a bike lump but any lowering of the max power revs brings a lower noise test revs which obviously makes life easier.
At Chelmsford where mine was tested they had no way of checking rpm - I had no rev counters on the car so he said "hold it at about 5,000 rpm" - I obviously took it to about 4,000 & it thus sailed thro' the noise test! (would probably have passed anyway). So if they are still relying on the customers rev counter would be a shame if it read a bit low
posted on 23/6/07 at 11:49 AM Reply With Quote
Of course if you've got a Racetech tachometer what you put on the form is irrelevant in as much as these dials have a rotary variable resistor on the back of the tacho allowing you infinite control over the displayed rpm.... It's a pain when you want an accurate reading for the sake of engine non-blowing-up though!!
I think I unfortunately had mine about 30% over-reading for the SVA.... So when asked to rev it to 4k I got it to a displayed 4k... Shame it was actually only 3k though.... Whisper quite on the noise test though!! Hehehe....
snapper
posted on 23/6/07 at 12:16 PM Reply With Quote
Rev limit it,
I think my megajolt is set to 6000 but feel it may be a bit lower soon.
I eat to survive
I drink to forget
Avoneer
posted on 23/6/07 at 03:02 PM Reply With Quote
Ok, I've put 10k on the form and posted it.
Might play with my digidash come SVA (cough cough) though.
Pat...
posted on 23/6/07 at 04:35 PM Reply With Quote
That's alright as long as the tester doesn't run it up to 10,000 after you've fiddled the rev counter
