badding
| posted on 10/7/07 at 10:42 AM |
ZX9R speedsensor mounting??
Hello
Does anyone has any pics how they mounted the sensor on their car, I´m in the progress of mounting mine.
[Edited on 10/7/07 by badding]
rpm
| posted on 10/7/07 at 07:18 PM |
see if these help, they take a bit of deciphering, 1st from rear below ,second looking rearward to the tunnel cheers Roger reverse what i said
above!!!
[Edited on 10/7/07 by rpm]
expert
ex= a has been
spurt= a drip under pressure
rpm
| posted on 10/7/07 at 07:20 PM |
how do you do the multiple pics?!!!
expert
ex= a has been
mistergrumpy
| posted on 10/7/07 at 07:47 PM |
Is that a bolt you've put into the adaptor flange? Are there not any issues with balancing problems?Why have the prop all balanced then bolt a
top heavy flange to it? Hmmm?
badding
| posted on 11/7/07 at 06:31 AM |
Did you use one or more bolts to get a correct reading on the speedo..
And as mister grumpy said, how about the balancing ??. I think you have to equally mount 2 bolts to the prop.
[Edited on 11/7/07 by badding]
rpm
| posted on 11/7/07 at 06:20 PM |
I've got 3 equally spaced bolts all drilled and mounted to give balance. 3 bolts gave a speedo reading at sva within limits so i didn't
really need my speedohealer
