Avoneer
posted on 28/7/07 at 09:25 PM |
Blade Gear Ratios and data for DD2
Can anyone help with the following parameters I have to put in in the Gearbox ratios screen:
Primary Ratio:
Gear 1:
Gear 2:
Gear 3:
Gear 4:
Gear 5:
Gear 6:
Also, Engine Ignition Pulses per engine cycle?
Pat...
bigrich
| posted on 28/7/07 at 09:32 PM |
what year blade Pat got the manual in front of me
[Edited on 28/7/07 by bigrich]
bigrich
| posted on 28/7/07 at 09:49 PM |
92-95 blade ratios
2.769 1st
2.000 2nd
1,579 3rd
1.400 4th
1.250 5th
1.174 6th
96-97
2.727 1st
1.933 2nd
1.600 3rd
1.400 4th
1.263 5th
1.167 6th
98-98
2.769 1st
2.000 2nd
1.600 3rd
1.368 4th
1.227 5th
1.130 6th
i think the primary is 1.500 and 2 pulses if i recall correctly
nitram38
| posted on 28/7/07 at 10:09 PM |
Sorry to hijack your thread, but talking of ratios, Chris Mason sent me a link to a program to work out speeds in different gears.
I can get the actual gear ratios for my 05 R1 from the manual, but I don't know how to convert the chain ratio to a final drive number for the
program.
My drive sprocket is the std 17 tooth one and my chain diff sprocket is 52 tooth.
Can anyone give me an accurate final drive number e.g. 1.2 etc?
I did try dividing 52 by 17 = 3.059 but it gave me silly speeds.
Should it be the other way around?
17 divided by 52 = 0.32
Either way I am unsure!
bigrich
| posted on 28/7/07 at 10:18 PM |
3.059 to 1 sounds ok for the final drive but you also need to add in the primary reduction ratio of the bike gearbox usually around 1.5 to 1.6 to 1
thus lowering the speeds shown in each gearby approx 50% or so, or is it a third
getting a bit pi55ed for the calcs
nitram38
| posted on 28/7/07 at 10:20 PM |
I knew something was wrong when my top speed came out at 180mph!
bigrich
| posted on 28/7/07 at 10:24 PM |
i would guess a 3.059 ratio would give in the region of 140ish mph max dependant on wheel size
nitram38
| posted on 28/7/07 at 10:32 PM |
I'll check it out tomorrow when I get in from work!
