Author: Subject: Blade - which way is 1st and 2nd etc.
Avoneer
posted on 2/8/07 at 10:22 PM Reply With Quote
Got my paddles on and not being a bike person, which way is 1st and then all the other gears?
When I pull the left hand side of the paddles, the spline on the engine rotates anti clockwise and vice versa.
Thanks,
Pat...
P.S. Me and Indykid both managed a stall and a drive out of the garage - 1st time under it's own steam.
mistergrumpy
posted on 2/8/07 at 10:25 PM Reply With Quote
Should be clockwise for 1st then anti clockwise for everything else. Pictur the gears like a hand with neutral being inbetween the thumb and fingers.Down with the pedal (that ain't there now!) then up for the rest
indykid
posted on 2/8/07 at 10:37 PM Reply With Quote
i only stalled it in sympathy for your stall................honest
i'm still not converted though, phil.
tom
zxrlocost
posted on 2/8/07 at 11:00 PM Reply With Quote
put it in neutral pat and rock the car put it in first then try that way again it should be rock solid
when you try the other way you should be able to go through a couple of gears
posted on 3/8/07 at 11:33 AM Reply With Quote
tom
If you'd taken it a bit further than just out of the garage, you would have been converted.
Phil
andrew.carwithen
posted on 3/8/07 at 03:38 PM Reply With Quote
It'll depend on which blade engine you have.
The 919cc works opposite to the 893cc due to being operated by rear-set linkages on the original bike rather than a direct gear lever.
Viewing the splined selector shaft end on,
my 893cc is (from neutral position) clockwise for 1st then anti-clockwise for 2nd gear upwards.
Hence the 919cc will be opposite to this.
Andy.
ChrisGamlin
posted on 3/8/07 at 04:58 PM Reply With Quote
Anti clockwise to go down the box into 1st if I remember the linkage I had correctly, which tallies with Andrew's observations above considering its a 919 engine.
