locoboy
| posted on 9/8/07 at 03:42 PM |
Another R1 emissions thread sorry
Sorry to bore you all again.
I need a duffers guide to my emissions readings at SVA
I had 2 fast idle tests
CO limit was 0.3 i was 2.24 and 1.79 respectively
HC limit was 200 i was 84 and 252 respectively
Lambda limit is 0.97-1.03 i was 0.94 and 0.95 respectively.
Natural idle test passed ok.
Can anyone suggest what i may need to do to gain better readings?
Locoboy
mike smith1
| posted on 9/8/07 at 04:02 PM |
I take it thats its a carb R1?
You could look at the tubes and fish tank valve option, worked a treat for me at SVA with our blade.
Mike
| posted on 9/8/07 at 04:27 PM |
Short of getting a full tune-up at a BEC friendly garage which has a Krypton tuner your choices are limited to either using something like an Gunsons
Gastester or a Colortune.
I got surprisingly close with my carbs using just a Colortune and a carb sync balancer. Infact, I got close enough to pass... It helped I've got
a sheddy old engine though so the limits aren't too onerous.
zxrlocost
| posted on 9/8/07 at 04:33 PM |
what kind of CAT do you have colin
smart51
| posted on 9/8/07 at 05:15 PM |
lambda of less than 1 means you're running too rich. low CO and low (one one test) HC means you should have an easy job of adjusting it. If
its a carbed engine, turn the idle screws in a touch until lambda is right.
My local MOT place let me use their gas tester for free.
locoboy
| posted on 11/8/07 at 03:08 PM |
Colin,
Do you mean idle screws or Mixture screws?
Locoboy
smart51
| posted on 11/8/07 at 06:37 PM |
Mixture screws, sorry. Idle mixture screws to be precise because they change the mixture at idle.
