Author: Subject: BEC speedo sensor
matt.c
posted on 18/8/07 at 05:25 PM Reply With Quote
BEC speedo sensor
Does my 99 ZX9R engine have a speedo sensor in the engine/gearbox?
ch1ll1
posted on 18/8/07 at 06:11 PM Reply With Quote
sure it in the front sprocket cover.
paul
matt.c
posted on 18/8/07 at 06:24 PM Reply With Quote
cool thanks, me and flak have been sorting my wiring out today, im glad he was about!!!
Do you connect the speedohealer between that and the clocks?
ch1ll1
posted on 18/8/07 at 08:28 PM Reply With Quote
you wont have a sprocket cover after you have fitted a prop
matt.c
posted on 18/8/07 at 08:42 PM Reply With Quote
so i have to mount one some where else?
Using the ZX9R clocks is there any particular sensor i should be using?
rpm
posted on 19/8/07 at 10:34 AM Reply With Quote
The speedohealer is a straght plug in to the bike loom if you buy the correct fitting kit, I used the bike sensor and positioned it on a fabricated bracket over the prop flange HTH Roger
matt.c
posted on 21/8/07 at 10:07 PM Reply With Quote
Have you got any pics of the bracket and sensor over the prop, please roger?
