Author: Subject: Fitting trickshifter to R1 question.
hobbsy
posted on 20/8/07 at 08:07 PM Reply With Quote
Finally getting around to doing this, shift rod fitment should be fairly straightforward and I should be able to T into any vacuum feed on the throttle bodies (?).
But what I'm not immediately sure about is the ignition cut, its a 2003 5PW injected R1 and it has a coil pack on top of each plug.
The wiring for the ignition cut however seems to be geared up for bikes with one of two coils.
How do I make it work on this?
I guess there is probably a common ground that could be switched which would cut the lot?
How have other people done it on this engine?
Probably a stupid question once I find my Haynes manual and look at the diagram but its all neatly loomed up at the moment and I can't seem it that well.
zxrlocost
posted on 20/8/07 at 09:02 PM Reply With Quote
isnt it a red and black wire from memory that feeds all four
hobbsy
posted on 20/8/07 at 09:03 PM Reply With Quote
But what is the firing sequence or is it a wasted spark setup? If it was just 2 wires they'd all be firing at the same time which I didn't think it did?
