matt.c
posted on 18/9/07 at 08:37 PM |
Extra carb spring
Fitted my cable to the carbs on my zx9r, all setup but i have found there is not enough spring pressure to return the pedal. Do you add an extra
spring to the carbs or the pedal? Please attach pics if you have any.
Many thanks locosters.
stevec
| posted on 18/9/07 at 08:43 PM |
I think pedal if you can, less strain on the cable.
Steve.
lsdweb
| posted on 18/9/07 at 09:22 PM |
matt.c
If you're going to compete at all you'll need the second spring on the throttle spindle / linkage not the pedal end.
Regards
Wyn
Jubal
| posted on 18/9/07 at 09:34 PM |
I have the same probem, I'm going to copy this setup on worX' car:
%20(993%20x%20660).jpg)
roadrunner
| posted on 18/9/07 at 09:36 PM |
If you look at where your nipple hooks to the throtle, you will see a nuckle, it has a small hole in the top, i hooked a long spring to that and
bolted it down where the heat sheild is, it was the only way i could find of doing it.
richard thomas
| posted on 19/9/07 at 07:16 AM |
I did both - throttles to ensure they close and pedal to give some more feel...
matt.c
| posted on 19/9/07 at 08:05 PM |
can you get me a pic of this please. I have had the carbs of tonight to have a look but i dont know where you mean.
roadrunner
| posted on 19/9/07 at 09:23 PM |
Give me a day or two, i run with the air box on now.
Jimbob
| posted on 20/9/07 at 07:30 AM |
I managed to hook one onto the cable shroud stop
Will take a pic later which will explain!
James
roadrunner
| posted on 26/9/07 at 08:21 PM |
  carb spring
roadrunner
| posted on 26/9/07 at 08:22 PM |
  carb spring
matt.c
| posted on 26/9/07 at 08:50 PM |
cheers for the pics. Will have a look at mine tommorrow to see how to do it.
