locosaki
| posted on 12/10/07 at 11:26 AM |
BEC engine swap
Hi all,
Just registered here today and I'm looking for a little advice,I have GPZ1000RX installed in my locost and the engine is on it's way
out,It's a 1986 model so there is no shame to it,My question is,I want to try and keep the swap over simple i.e using the same cradle and bottom
montains sproket adapter etc,so basically it would be just a straight swap !!
Is there any other engine I could use apart from the above,I was thinking maybe ZZR 1100 ?
Any input will be much appreciated ??
Cheers Mike
dan__wright
| posted on 12/10/07 at 12:21 PM |
not sure the mounts would be the same so may have to change the cradle, the prop adaptor may be okay, plumbing will be different and in your going to
injection you will need a high pressure pump
FREE THE ROADSTER ONE…!!
locosaki
| posted on 12/10/07 at 12:25 PM |
Thanks for that Dan,If I want to keep it simple I would have to use another GPZ unit then,I was hoping one of the older units that kawasaki produce
might have had the same mounting points.
[Edited on 12/10/07 by locosaki]
Guinness
| posted on 12/10/07 at 01:03 PM |
Hi Locosaki
Welcome to the mad house.
As far as I know the GPZ900 and the ZZR1100 used the same block, with just changes to the bore and stroke. I'm not sure about the GPZ1000
though!
I can check the manual when I get home, but in the interim I have a couple of dimensioned photos of my engine cradle (for a ZZR1100).
  zzr1100 cradle dims
I know the ZZR1100 and GPZ900 sumps are the same shape (apart from the depth and routing of the connections).
Hope that helps.
Mike
russbost
| posted on 12/10/07 at 03:14 PM |
I believe the gpz1000 is the same as the old ZX10, if so you're in luck because the zx10 & zzr1100 are identical apart from a few internal
bits - I have a zzr1100 side casing on one of my zx10's
locosaki
| posted on 12/10/07 at 05:49 PM |
That makes sense,The version I have is the ZX10 A,if that means anything ??
Minicooper
| posted on 13/10/07 at 08:24 AM |
I think the blocks are almost identical as far as I know, I heard about swapping of sumps from the GPZ900 as well.
They don't use fuel inection either so your fuel system should be fine.
Also I just happen to have a ZZR1100 D3 with ancillaries for sale, if your close enough come and have a proper measure up
I'm based in Chandlers Ford, Hampshire
locosaki
| posted on 13/10/07 at 12:48 PM |
Hi Mike thanks for the pic with dimensions,If you have anymore info that would be appreciated !!
Hi David,Unfortunately I'm up in Scotland but thanks for the offer,If I do manage to find if it fits I might well be interested mate !!
I'll keep an eye out here as hopefully someone will know.
Cheers Mike
locosaki
| posted on 15/10/07 at 07:02 PM |
So with mine being on it's last legs the ZZR1100 should be a better/more powerful option that the GPZ1000RX ??
