Adam
| posted on 19/11/07 at 10:00 PM |
Clutch... ?????
Hello more questions i'm afraid...
Right, am i right in thinking that if it is in gear and you put the clutch in the car should free roll as if it was in neutral, like a car? or am i
wrong. Juat when i pull the clutch cable on mine and it's in gear it don't butch? or has something gane wrong with my clutch?
Any advice would be great.
Sorry, it's a 2000 R1
Adam
[Edited on 19/11/07 by Adam]
ReMan
| posted on 19/11/07 at 10:09 PM |
YOU ARE CORRECT!
Just when i pull the clutch cable on mine and it's in gear it don't butch?
IS THE BRAKES STUCK ON?
VERY POSSIBLY!
DONT EAT YELLOW SNOW
I BET YOU ARE NOW!
ONLY KIDDING
Adam
Adam
| posted on 19/11/07 at 10:11 PM |
lol thanks for the reply....
guess something is up with my clutch then and ideas anyone?
ReMan
| posted on 19/11/07 at 10:16 PM |
Does it move OK in Neutral?
Is you're engine running yet?
What pedal and cable have you got, did you set it up?
Sounds like it's not releasing if the other pointas are covered, may just be down to adjustment.
At the risk of OVER clutching, which can cause the opposite problem on R1 ie no drive, bear in mind that the difference between open and closed is
very small on a bike engine, it would not needto be far out to not release at all.
Does the clutch "feel" right?
As many questions as answers, sorry....
Adam
| posted on 19/11/07 at 10:19 PM |
yeah moves fine when in neutral, engine is not running yet. We've used the orginal R1 clutch cable connected to the MK pedals. Clutch feels
ok... well it does to me, don't laugh but never been on a bike before so wouldn't know how one feels
ReMan
| posted on 19/11/07 at 10:23 PM |
OK, If it feels OK it probably is.
It should feel same as a car , just lighter.
Are youi sure it's pulling up enough?
Try pushing the lever on the engine by hand, or with the end of a hammer handle works well, see if it moves a tad more and then releases.
You've not modified the clutch itself have you ? New springs or plates?
Was the engine seen/heard or known good?
[Edited on 19/11/07 by ReMan]
Adam
| posted on 19/11/07 at 10:30 PM |
Yeah tried pushing it a bit more and to be honest it did move, but tried pushing the car and it still didn't move. Not touched the clutch at
all, just cleaned up the outside of the engine.
No didn't see it running starting to worry now.
ChrisGamlin
| posted on 19/11/07 at 10:35 PM |
Its possible if the engine has been standing for a while that one or two of the plates have dried out a bit and stuck to the adjascent plate.
I wouldnt worry about it at the moment, when you've got it plumbed in, run the engine up to temperature with the clutch pedal held down and you
may find it releases itself as it warms up. If not, a gentle push of the car with it in gear and the clutch down might just give it enough of a jolt
to free up. worse case scenario is taking the clutch plates out (an easy job) and either freeing them up or replacing.
Adam
| posted on 19/11/07 at 10:36 PM |
thanks for the advice guys... much appreciated.
Adam
ReMan
| posted on 19/11/07 at 10:44 PM |
Yep, as Chris said too, it all sounds OK and you can't really do alot mre until it's running, which is why I asked.
I certainly would'nt strip it or mess any more yet, As said, it's not a big job and can be done without taking the engine out.
Hurry up and get it running, it's a great milestone
Colin
yorkshire-engines
| posted on 20/11/07 at 12:25 AM |
Its as Chris says your clutch plates are stuck it will free off when engine is started let it get warm and with brakes on depress clutch and
engage 2nd gear there will be a clunk and thats it
the r1 suffers from clutch stick when been stood a while
cheers malc
locoboy
| posted on 20/11/07 at 08:09 AM |
Agree with the above,
My 1999 R1 was stood for 18 months before i used it and it was rock solid, it didnt free off when it got up to temperature either.
I put it in gear and depressed the clutch and OX pushed it back and forth in a angry manner and we heard a clunk and it came free.
Job done never had a problem with it sticking on after that.
Locoboy
