stuart_g
| posted on 4/2/08 at 12:16 PM |
BEC radiator fan switch
Do you normally use the one from the bike or don't they fit car radiators.
Is it a case of finding a car one in the right temp range.
I need one to fit a Polo rad for an 05 R1 engine.
[Edited on 4/2/08 by stuart_g]
| posted on 4/2/08 at 02:55 PM |
Most people use the polo one cos it fits the polo radiator
IIRC you want the two-wire sensor and there are two different temperatures available.
bigrich
| posted on 4/2/08 at 09:41 PM |
why do you need a rad fan switch,the ecu of the bike turns on the fans, the 05 R1 rad does'nt have a switch in it
[Edited on 4/2/08 by bigrich]
stuart_g
| posted on 5/2/08 at 06:39 PM |
When I had the R1 loom stripped of all the bits I don't need the rad fan wires were taken out also.
I am now going to connect the fan switch wire of the car loom to the ecu so it will turn the fan on and off as required, that way the ecu will monitor
the coolant temp sensor behind the cylinder head which is a better location than in the rad, also as you say no need for a switch in the rad
itself.
now all I need is a blanking plug for the rad.
| posted on 5/2/08 at 07:18 PM |
Leave the switch in with no wires connected.
tks
| posted on 5/2/08 at 08:08 PM |
M22x1,5mm is the thread of normal temp rad switches...
sow you can buy a nut and make a temp sender tube.
Tks
stuart_g
| posted on 5/2/08 at 08:26 PM |
I haven't got a switch.
