Author: Subject: Busa clutch M/Cyl
Jason Fletcher
posted on 7/2/08 at 10:33 PM Reply With Quote
Busa clutch M/Cyl
Hi guys
I think I need a 1/2 inch master cylinder with 1.5 inch stroke for the busa clutch. I have fitted it up using the bike one which has a 1/2inch 1 inch stroke and its only moving the clutch rod about 4mm in. Is 4mm enough? Or shouid I go for a 5/8 bore cylinder? I am guessing the slave I have is bigger dia than the standard busa one.
Assuming I do need this 1/2" 1.5 inch stroke cyl, any ideas where do I get one from?
Thanks in advance
Jason
[Edited on 7/2/08 by Jason Fletcher]
richard thomas
posted on 8/2/08 at 12:46 AM Reply With Quote
4mm might be enough, they don't need much to disengage....
mackei23b
posted on 8/2/08 at 09:47 AM Reply With Quote
I had a ZX9R B type with a hydraulic clutch and 4-5mm sounds about right
