| posted on 9/11/03 at 09:56 PM |
Clutch & Accelerator Cable Advice...
What do the rest of you guys out there use for Clutch & Accelerator Cables... any links, iformation and/or advice would very much help!
Thankx in anticipation!!!
OX
| posted on 9/11/03 at 11:42 PM |
i made my own but you should be able to get some made for £15 ,i attached them to the pedals by using a 6mm bolt with a top hat spacer so that it was
able to spin in the pedal then driled a hole in the bolt behind the spacer just bigger anough for the cable to go through and then clamped it using a
washer and nylock nut,i know that maybe clamping the cable isnt the best way to do it but it works fine
loafersmate
| posted on 10/11/03 at 08:42 AM |
Used a blade bike clutch cable and inner/outer cable from a push bike for the accelerator......about £5 for the lot.
Ben
| posted on 16/11/03 at 09:33 AM |
Blade Clutch Cable...
Ben... does the blade clutch cable fit then?
Got the rest of it sussed now... every step we take, you lads all know about!
loafersmate
| posted on 17/11/03 at 08:20 AM |
well it does on mine!! you have to cut the nipple off right at the end, I turned up a cable stop to fit in the tube on the chassis and then clamp the
cable to the pedal with a drilled bolot and spacer...........my chassis is about 2 years old so the design for the clutch cable routing may have
changed now??
Ben
ChrisGamlin
| posted on 17/11/03 at 11:18 AM |
The no hassle route when I did mine was the Westfield Megablade items, cost about £25 for both IIRC, although this was about 2 years ago too, so
prices might have changed and others might supply similar now.
Chris
